:: Chris ::
Poster un nouveau sujet   Répondre au sujet    LAVERDAMANIA Index du Forum -> Presentation -> Who are you? (Registered members only)
christulin
Vos motos: 1984 RGS
MessagePosté le: Dim 30 Sep - 01:34 (2012)    Sujet du message: Chris Répondre en citant
I traded bikes last year for a 1984 RGS 1000 that I have always wanted.  It was a nonrunner from negletct for 10 years.  Carbs have been rebuilt, fuel tank cleaned and seased, bodywork repainted, electrics sorted, fluids changed and now running.  Rusty chain replaced.  Still needs sorting.  This is my first Italian bike.  I have wanted a Laverda since I was a poor young man and now have a fast, attention-getting exotic bike.  Quite different from the brit bikes I have usually ridden and worked on.  Nice to have electric start, disk brakes, electronic ignition to make it more practical than my older bikes.
MessagePosté le: Dim 30 Sep - 01:34 (2012)    Sujet du message: Publicité
MessagePosté le: Dim 30 Sep - 09:55 (2012)    Sujet du message: Chris Répondre en citant
welcome to you on laverdamania and please you can put picture of your bike , we like that on this forum Okay
Blue981
Vos motos: Various Laverdas
MessagePosté le: Dim 30 Sep - 12:40 (2012)    Sujet du message: Chris Répondre en citant
Welcome Chris.
Sounds like you brought one back from the dead.
It's a pretty rare bike in the US, no?
MessagePosté le: Dim 30 Sep - 12:41 (2012)    Sujet du message: Chris Répondre en citant
Welcome Chris! Your RGS will satisfy you in any respect but most probably you'll have to replace your ignition (if original) to get a perfecly reliable bike and a smooth engine. Fast, easy and relatively cheap on this 120 engine. In the meantime, you can just shunt the ballast resistors to avoid most of the problems (mainly fooling the plugs at low rpm).
christulin
Vos motos: 1984 RGS
MessagePosté le: Dim 30 Sep - 22:30 (2012)    Sujet du message: Chris Répondre en citant
Thank you.   Laverdas are very rare in the US, but still legendary.  I traded an Indian m.c. for this bike.  It was originally purchased in Switzerland, then by a local man who was a Laverda dealer.  It is nearly all original, including the ignition system..  It has been fouling plugs, so I may try bypassing the ballast resistors.  The carbs were restored by Wolfgang Hertner.
MessagePosté le: Dim 30 Sep - 23:41 (2012)    Sujet du message: Chris Répondre en citant
These BTZ ignitions are simply weak, especially at low engine speed. Add to that that the advance curve doesn't really exist (more like a "step"), you won't recognize your engine since you'll fit a decent modern ignition!
christulin
Vos motos: 1984 RGS
MessagePosté le: Dim 7 Oct - 22:00 (2012)    Sujet du message: Chris Répondre en citant
Chris's 1984 RGS.
MessagePosté le: Lun 8 Oct - 00:15 (2012)    Sujet du message: Chris Répondre en citant
Sorry Chris, the picture doesn't appear.
Process is described here: http://laverdamania.xooit.fr/t1064-How-to-post-pictures.htm#p11517
Scrumpyjack
Vos motos: 1974 3C, 1982 Jota,
MessagePosté le: Ven 12 Oct - 00:06 (2012)    Sujet du message: Chris Répondre en citant
Chris,
You choose the right Italian bike and you wont regret owning a Laverda. I am sure that you will experience a bigger grin riding any Laverda than you have on any other bike.
Scrumpy
I will learn to speak the French language but please dont rush me.
christulin
Vos motos: 1984 RGS
MessagePosté le: Mer 26 Déc - 00:16 (2012)    Sujet du message: Chris Répondre en citant
Chris's 1984 RGS:
MessagePosté le: Mer 26 Déc - 00:45 (2012)    Sujet du message: Chris Répondre en citant
Nice example Chris! Interesting that you have the plugs on the headers for a CO2 analyzer.
christulin
Vos motos: 1984 RGS
MessagePosté le: Sam 29 Déc - 03:14 (2012)    Sujet du message: Chris Répondre en citant
Any idea how to hook up a CO2 analyzer to the headers?
Right now, the bike is halfway stripped down for sprucing up, checking valve clearances, replacing wheel and yoke bearings, rebuild brakes, clean up electrics, etc.  It should look and run better by spring.
MessagePosté le: Sam 29 Déc - 04:50 (2012)    Sujet du message: Chris Répondre en citant
You can simply use a Lambdatester or similar, just plugging the sensor into the headers the time to check the mixture ratio.
About the valve clearances, I suppose that you know already that the cylinder head torques as indicated in the factory manual are wrong. Any torque above 25 ft/lbs has a good chance to strip the threads in your crankcase... This is the correct torque figure:
MessagePosté le: Aujourd’hui à 16:08 (2018)    Sujet du message: Chris
Poster un nouveau sujet   Répondre au sujet    LAVERDAMANIA Index du Forum -> Presentation -> Who are you? (Registered members only) Toutes les heures sont au format GMT + 2 Heures
